Jeep TJ - Must See - SoCal
v8turbo
Got transferred, must sell. My loss is your gain. Built, solid, professionally maintained, no shortcuts. One look and you will see what I mean.
$15100
66k miles
Soft Top
Stock 6 cylinder.
Automatic
Transmission - new torque converter & seal.
4.5 Rubicon Express Lift
Dana 44 Axles out of a '05 Rubicon with factory Jeep Air Lockers
Sway Bar Disconnects.
Rubicon Express shocks F- RXJ701B R- RXJ704B.
NEW tires 33 x 12.50 R 15 Toyo MT with spare.
New Steel Radiator - Lifetime warranty.
SS brake lines
Brakes, over size rotors slotted / semi mettalic pads
Banks Intake
Slip yoke eliminator
Custom Drive shafts
Heavy Duty tie rod (spare tie rod under hood)
Terra Flex 9550 Steering stabilizer.
New Gibson exhaust
New Gibson Ceramic coated Stainless header
Full Rock Hard roll cage
Riddler front and rear diff covers
Rear Diff skid plate
Skid plated engine, gas tank & steering box
Body Armor front and rear bumpers
Poison Spyder front & rear fenders with crush corners and sliders
Or-Fab Swing Away Tire & Can Carrier with 2 fuel packs and 2 storage packs with locks
Hi-Lift Jack
Roto Pax
Warn Winch
Air, Heat & Ice Cold A/C
Rigid Industries Dually D2 rear back up lights
Rigid Industries Dually D2 Pillar mounts on KC Brackets
4 HID driving beams on front
SafeGlo LED Whip
LED Tail lights
Kenwood stereo with I-Pod connections
CB Radio FireStick Antenna - tall and short
4 Sony Explode speakers
Flat-tow bar included
Blue OX Towbar Included.
Recently replaced starter
New Battey
Tilt steering wheel
Driver & Passenger air bags.
Pro Plug 7Way
New Factory - AC controls
New Factory Head lamp controls
Etc... its sweet.
Full lube service at 65k. Diffs, trans, transfer, motor. All hoses/belts/radiator/thermostat/cap replaced.
v8turbo
Also ... Rebel Offroad did most of the build and Jeep is a 1999.
Any questions, PM and ill give you number or call you.
Mark
flipstick
