sandalscout
Hey all,
I'm gathering parts to convert my cooling system from closed to open (and eliminating the heater valve and leaking coolant bottle), and am also installing an aftermarket cooling temp gauge. I'm looking for some insight into the temp probe placement.
I found a writeup where someone used a 3/4" tee, and put barb fittings on 2 two sides, and an adapter to plug the probe into the middle section. He spliced this into the middle of the heater hose going to the core. I have assembled one of these, with the intention of doing the same thing, but had another idea.
I am using an adapter (http://www.jegs.com/i/Moroso/710/63730/10002/-1) to add the filler neck and cap into the upper radiator hose. What if I tapped this to fit the probe into the side of it? My initial concerns are that the probe is after the thermostat in both situations (but this is normal, right? too cool = thermo not opening?) and that the neck will be cooler than a true reading do to air sitting around it? if the neck is inline in this area, though, I think most of the air will settle out in the rop of the radiator eventually.
Any thoughts? Appreciate it!
