dirty Bakers
Conservative
So what kind of spout is common out there, the ones I have used I was not impressed with.
That is the one that I have. I modified mine by getting the unleaded end of the cheap chinese kind pictured hereEveryone is correct. The super siphon is fantastic, but when you just want/need a spout the standard semi flexible units for NATO/Wedco work well. However, when only the best will fit the bill I highly recommend this little gem.
http://www.pinzgauer.com/showdetails.php?cat=surplus&partno=SAV4220
It is absolute incredible. I ordered two of these and will use nothing else now.
I'm using the good old blitz jerry can. the super siphon is a great Idea.
I tried the HF version of that and could NOT get it to do anything. Was it the Chinese instructions, the equipment or the operator? Should I try to name brand? Is there a trick to getting them to work?
Super Siphons can be ordered from ExpeditionExchange.com.
The visual is great for those of us who are instructionally challenged. I think I tried that with the HF version, so I'll try again with the real thing. Thanks.
