Finally got rid of the stock bumpers.
Front:
I wanted full width coverage, access to my winch drum, able to mount LED lighting, retain the stock fogs.
So, i ended up with the E1 bumper.
20" Rigid Ind Combo bar
Warn VR10000-S
While the VR series Warn's are not at the top of their foodchain, I feel confident that this winch will do well. I had to modify the solonoid bracket, bolts, and mounted over the drum vs off to the side. This was the only way to integrate the 20" Rigid with it. I can rotate the solonoid box up if needed to get at the rope. I have about 1.5" between the final wrap and the box. figure if you're winching, you'r pulling out two wraps min. anyhow. So should be OK there.
Front:
Warn VR10000-S
