JK with Nth Degree 4" lift
haven
Here's a couple of photos of a JK with 4" lift
from Nth Degree, with 35" tall tires. 35 is all
that will fit due to the extreme articulation
this suspension makes possible.
Sweet ride! Read the story at
http://forum.jkboard.com/viewtopic.php?t=3296
Chip Haven
2500Adventures
nice rig, there is one here in memphis (2-dr though) that is running a 4" lift with 37s tucked underneath it, very nice looking rig....i'll have to find a pic of it to share
Dirty Harry
Micheal is in Moab this week putting that Jeep through its paces. :punk03: He said that is rides CONSIDERABLY better on the street with the Nth Degree suspension.
Gear
Explorer, Overland Certified OC0020
Maximumrob wrote
I would have added an inch of bumpstop to run 37's.
Why 37's, do you think the larger tires would really be beneficial for the extra stress that is put on the other components. Woundn't mind some thoughts sense I am first on the list for this Nth degree kit when it hits the public. I guess I am also asking because I went with 33's on my 03 Rubicon and then about a year later switched to 35's. I really don't want to make this mistake twice. Anyone, thoughts!
ox4mag
I think it really just depends on what you plan to use the vehicle for. I'm still running the stock 30s (or 31s) on my '05 Rubicon and I've been able to do everything that I've wanted to do thus far including some pretty sick stuff up in Colorado near Great Sand Dunes. If you want to do hardcore rock crawling, then the larger tires and lift will provide the clearance you need. However, if you're more interested in enjoying backcountry trails, with moderate obstacles, and more vehicle-dependent travel, I wouldn't suggest going up to 37s. One thing to keep in mind is that once you spend the money on lifts/tire size increases, you'll keep spending and spending and spending...
Good luck either way, hope this helps!
saltamontes
my understanding of nth kits (and most kits in general) is the weak link is the bushings.
they had probs w/ the bushing getting worn/sloppy w/ the orig TJ kit.
not sure if they addressed it (there was talk of an aviation type stainless mesh bushing, not sure how seriously considered though) in the JK.
Dirty Harry
That is the first time I have heard that. Have you seen their bushings? They are different than anything else on the market, they have a ball and socket design with different durometer bushings on the front and rear. You can easily change out the bushing for different durometers if the wear is too high.
2500Adventures
The JK owner of this rig owns a shop up in Big Bear that specializes in Nth Degree kits. They are also a big supporter of the Jeep Liberty (KJ) crowd.
I believe this is a Nth degree kit on their rig, but not 100% on that. Heather and Quinn at All J products. www.boulderbars.com
saltamontes
yeah, when i first saw the kit i thought that it solved many of the probs w/ standard donut bushings or heim type joints re wear.
however talking to installers at last yrs offroad expo in pomona, they said that there were probs w/ the bushings and that nth was adressing them.
not sure if mult durometers was the fix. i hope they got it fixed as their kit seemed to be a good design.
bushings have been the weak link in RE/FullTraction/Fabtech/etc. never understood why they could not get them to last as long as OEM rubber.
maybe they finally found a good source.
i am about 1.5 yrs out of the jeep research (so my comments are dated) but thinking bout the JK if they put a hemi in it.
maximumrob
Gear said:
It's all about that "envy" factor. I know somebody on 35's that went to 36's, then met another on 36's that went up to 37's. 33" guys are always looking to squeeze in 35's, and we poor saps on 31's are looking for anything!
There will always be some obstacle somewhere that'll make you say, "if I only had another inch of clearance!"
SeaRubi
35's seem to wear well on the body of those. and with all that wheelbase, it seems like a bigger tire is justified to help out the breakover.
