The custom aluminum I had made for the JK is just a bit too wide for the TJ, so I am seeing if anyone is interested. It can be held down with nutserts of 1" ratchet straps using the stock JK tiedowns.
The bottom piece is 10" tall. The next piece is 4" tall and holds a folding plastic table - the table it is sitting on. The large "box" on top is about 17" square and has straps to keep your gear from hitting the rear window. The space to the right is wide enough for an ARB fridge.
You will need to remove you subwoofer to use - hence the reason for me selling the subwoofer delete panel also.
The aluminum is 1/8" thick and was not cheap - about $400. If interested send me a message. It works great for keeping your gear secured when wheeling which is something everyone should do.
$350 for everything.
Pick up only.
Maryland 21084
Pick up only.
Maryland 21084
