Jomax Customs 2007-2021 Tundra ABS Sensor Armor info/install
14burrito
Hey everyone!
Got around to installing Jomax Customs most recently released product, their Tundra 2007- 2021 ABS Speed Sensor Armor!
Super simple install, couple bolts on the front and a couple bolts on the rear. All very easily accessible hardware, making at home install a breeze for all you enthusiasts :)
Pictures of my truck as well as some local AZ members who have also installed them.
The current market offerings have an opportunity for the guard to rotate. They utilize one extended length bolt, single shear point. Not fully enclosing the sensor, protecting only the front face. All those topics and more are addressed with the Jomax design.
Big question asked in regards to "Why would I need these?" - the OEM location of the ABS sensors leaves them very exposed, vulnerable to being damaged both for street and offroad use. On the street, one encounters trash/road gator while offroad we encounter branches, twigs, unknown debri under water, mud and small rocks being kicked up/flung around.
These are cheap insurance to protect those sensors which could cost upwards of $450 to have diagnosed and replaced at a dealer. The sensors themselves run about $225-$250 ea and sensor orientations are different....so which one do you choose to keep as a spare? Do you buy one of each? - no, that would just be silly.
Currently have a Group Buy running for these and the Rear Diff breather extension/relocation kits that Jomax Customs makes. Feel free to send me a PM/DM for more info! :) GB ends July 19th.
Key features:
These units prevent shearing of single mounting point.
They have multi-point load distribution.
They are designed to allow proper movement of the abs wire, non abrasive contact.
They intentionally reuse the factory hardware to reduce premature deformation of connections.
They protect additional hardware and sensor points.
Designed- Engineered- and Manufactured in the USA.
Covered under multiple patents and trademarked with USPTO.
Only tested ABS product on the market with data and video results for product comparison.
