Just lucky I guess!!!
blue bomber
After getting my 88 mostly smoothed out, I have been enjoying driving around without my top on. My luckless friend's dodge cummins truck decided to simultaneously eat the lift and injection pump. To the tune of $2400, ouch."I'll take you home. Just gas up the rover."
His luck extended to me. A tooth broke off the starter ring gear. $10.00 part but hours to replace.
Really my fault for not checking the engagement.
3 hours later
Offending part
Heartless
New gear installed
Checked engagement, like I should have in the first place.
Used a jump start box to turn the motor on the ground to check the pattern.
Back in. I'll get it running sometime this week. I'm being punished for something!!??
LR Max
Local Oaf
Meh. All last year I wrestled with my transmission all last year. Finally got that sorted out just in time for all of my valves in my cylinder head to die.
On the flipside I did drive that truck a lot last year on trips. Hardly ever to work but a few Sunday hit-the-roads. Your time will come!
proper4wd
Matt I remember reading in a different thread about your suspension setup on the 88 but I dont remember the details and can't find the thread. Could you quickly explain what you've done for springs/shocks and how you've mounted them? From the photos I saw it has some very good travel.
blue bomber
The front has stock rover front springs with military shackles. I have castor correcting shims. I used longer shocks and relocated the upper mount with Ford truck brackets. The rear is stock Santana parabolics with longer shocks and military shackles. I plan on longer springs for the front. But it can wait. I just want to put some miles on it.
blue bomber
17mpg on the freeway and 13ish around town. I have 19 gallon fuel tank. About 290-300 bhp and 350 ft lbs of torque. Well worth the fuel economy penalty.
JSBriggs
Penalty? Thats about the same mileage as the stock 2-1/4 but with much more power.
-Jeff
graniterover
Briggs beat me to it. I've never been above 14 city or highway with a 2.25. Last year I was at ~12 or so. With new tires and a tune up I'm hoping for 14 again.
I did pick up a 465 for your adapter. Maybe I should finish it... One of 100 unfinished auto projects.
dhuss
