King Starboard
Dr. Cornwallis
I'm thinking about using King Starboard as an alternative material to plywood for the bed drawer/sleeping platform in my second gen Tacoma. Is there any compelling reason not to use this material? I like that it's more weather resistant than wood, although I believe it is a little heavier and more expensive.
86cj
It might not be rigid enough even when thicker and heavier, the sawdust is hard to pick up with the static but it drills great. I do like it though and use it if possible you just have to get used to it......
Dr. Cornwallis
It would be spanning the width of the bed with a support running down the center (also where the two drawers will split), would this not be enough support to prevent sagging?
doug720
I have made many projects with StarBoard. It's a great material, but has a couple of issues.
Mainly, it's expensive and heavy. Plywood is just the opposite.
It needs supports, but if you use it, a center support will be more than sufficient support.
Dr. Cornwallis
I thought I would bring this back to life. I've put off building the platform as I decided a while back to sell my 2nd gen Tacoma for a 3rd gen. My 3rd gen is almost here and so ill be getting started soon.
I debated using wood instead for a while for the weight savings but after visiting a local plastics company that sells King Starboard, I've decided to use it.
My plan is to use mostly 1/2 in Starboard for the top (the actual sleeping platform) and for the drawers with 1in Starboard supports spanning the width of the bed every 18 in with a middle support running the length of the bed.
They also showed me a PVC product that is much lighter than Starboard, and cheaper, but not as strong. I'm considering using this for the drawers to save more weight. But not sure yet.
I decided on Starboard for durability. I like the idea that it basically lasts forever, I can clean it with a hose and never have to worry about it rotting.
Clemtiger84
