Kinsmen shower Drop Stall $400
brookie0907
$400 + actual shipping from 28602. Will to arrange pick up within an hour travel.
Used stall in excellent condition. These are very stout. If you know you know. Only selling because we are changing our set up
I don't believe these are being sold anymore. It was a one man shop.
Designed, Sourced, and Built in the U.S.A.
• Rapid deployment and storage
Cordura® 500D solution dyed mil-spec fabric cut and sewn in-house
• 18oz vinyl coated polyester cover with flexible YKK coil zipper cut and sewn in-house
• Fabric attached with buckles to easily rotate zipper opening direction
• Fabric height adjustable at each corner buckle webbing
• Upper and lower two-sided YKK zipper with paracord pulls
• Stake webbing loops at each bottom corner for greater stability
• Guy-line attachment webbing on each side for wind stability and increasing space inside
• Stainless and brass hardware with poly bushings in each arm hinge, just like our awning
• Semi-gloss black powder coated steel tube frame for maximum strength and reduced weight
• Easily attach items to frame with magnets
Chonker LMTV
