Knuckle Offroad rear bumper and tire carrier
Out2PLAY
Knuckle offroad bumper with vertical tire carrier. Carrier is modified for highlift and better support for the tire
Also added Off Road Telescopic LED Light Pole with LED
Bumper is in great shape
Bumper / tire carrier with three LED lights and two gas rotapax
$900
LOCAL PICK UP ONLY
Specs
Rear Bumper Specs:
CAD design is CNC cut and bent then hand welded, ground, and sanded to perfection.
3/16" steel body,
1/4" steel mounting bracketry for strength.
Maximum ground clearance for improved departure angles.
Maximum clearance on sides with wrap around body protection.
Easy installation with the use of OEM mounting holes with an additional two holes for strength.
Integrated 3/4" thick d-ring mounts included.
Integrated 2" receiver hitch included.
Includes grade 8 hardware for mounting.
Vertical Tire Carrier Specs:
1-3/4" base diameter spindle, dual tapered roller bearings.
Zerk fitting on spindle for grease to ensure a long trouble free life.
A combination of 1/4"and 3/16" "I" beam design for strength and stability
Two Mounting Configurations conventional (vertical) or slant (designed to work with the angle of the Trektop) with the addition of our "Skewer" bracket.
5/8" Heim Joint link to connect the backing plate to allow for the tire carrier to open and close with the latch on the OEM tailgate.
1 1/4 " hitch to allow for trail rack or a license plate relocation
Integrated CB antenna Mount
Allows for mounting of a 32"-40" tire with adjustable offset bracket.
dhuss
