KONG !!! SURVIVAL UNIT REDUCED $ - $67500 (la pine, Oregon - USA)
Jjackson410
Found this little gem on CL Spokane. Not mine
https://spokane.craigslist.org/rvs/d/kong-survival-unit-reduced/6774945949.html
DEATH IN FAMILY FORCES SALE
ONE OF A KIND AND CANNOT BE REPLACED --- THIS IS THE ULTIMATE COACH TO GO ANYWHERE
YOU MUST SEE IT TO KNOW TRUE QUALITY AND APPRECIATION FOR DETAIL
THIS unit was engineered and custom built with a 16' 4" x 8' FRB motor-home body.
A highly structural FRB Core sandwiched between 2 layers of fiberglass 3 ply total 1/2" outer skin.
Steel beams were added on 16" centers for all walls.
3" I-beams for the entire floor on 12" centers for unmatched strength.
The walls were double wrapped with block foam between 2 layers of Prodex.
The side walls are 2 1/2" thick with incredible 'R- value of 31 for extreme cold and heat.
The ceiling is 5" thick and 'R-value of around 47.
The floor is 7" thick and 'R-value of around 56.
It has an interior height of 6'6".
Most all "expedition style vehicles have very low 'R-value ratings.
There is nothing like this unit available ANYWHERE!
Most "expedition" style motor-homes have cost starting around $200,000.00 and some have starting prices of about $1,000,000.00.
An Earth Cruiser, with canvas pop-up side walls can sell for over $200,000.00.
Read on, to be AMAZED at just how safe you can be.
--- Wood grain 'Congoleum' flooring throughout.
--- Solid rustic hickory interior by McClusky Custom Cabinetry
--- Wood was Grain Cut to match. (It's the nicest interior of ANY Expedition Vehicle anywhere)
--- Oversized pass through storage compartment accessible from both sides (full 8 foot width)
--- Three "Protech" Steel under body storage boxes
--- Painted body to match truck
--- Body graphics painted by Ed Hubbs of Full Blowin Kustoms (blends with the surroundings)
--- Dometic skylight with integrated blinds and mosquito screen (when opened you can get onto the roof)
--- Full LED interior lighting
--- Powered HD TV antenna
--- Wired for flat screen TV
--- Wired for two Ham Radios - 10m and 2m/40 (antennas on roof)
--- Queen size memory foam mattress (10 inches thick)
--- Above bed and top of bed storage
--- Deep wardrobe closet for hanging clothes
--- Huge 11" wide by 6' tall pantry with 2 pull out drawers
--- 2 special 60" long drawers under bed (long items? weapons?)
--- 6 under bed clothes drawers
--- Lots of cabinets throughout coach
--- Full boxed cabinets, not just faced
--- Hidden compartment with electric lock
--- 105 gallon fresh
--- 40 gallon grey
--- 40 gallon black--- both tanks are vented utilizing an Extreme Swivel Vent
--- All drawers are equipment with KV roller slides, HD side mounted 20 lb. pull
--- 24.1 gallon propane
--- 32' x 32' full fiberglass shower (full height with door)
--- Dometic Revolution Ceramic toilet bowl. Uses about 1 pint water per flush (separate from shower)
--- 13 stage UV water purification system (can take water from any fresh water source, river, pond, lake etc) then kills 99.9% of all bacteria for complete survival.
--- Plumbed in 'PEX' throughout
--- Attwood 50k BTU on demand tank-less water heater. Good to -15 degrees
--- Large stainless deep dish MOEN sink
--- Espresso counter top with stainless steel range hood
--- Pull out spice rack
--- 30k BTU Suburban 12 volt forced air heater (along with wood stove there are two heat sources)
--- Custom wood stove built for expedition motor-home use and designed for survival heating and cooking
--- Custom aluminum real and side panels around wood stove with Micor (1000 degree rating)
--- Extreme stove pipe and rain shield
--- WFCO Ultra electronic distribution center (mounted in steel box, under refrigerator)
--- Magnum 2000 watt pure sine inverter / charger with inside remote controller
--- 30 amp Marinco Marine power inlet and cord
--- 4400 watt generator with 110/220 volt on a pull out tray
--- 2 deep cell 12 volt house batteries on pull out tray with room for two more
--- 4 Rockford Fosgate ceiling mounted speakers
--- Samsung DVD,CD 100 watt stereo unit
--- Wired for roof A/C
--- Folding aluminum steps
--- Rear LED stop and turn signals
CALL TO SCHEDULE YOUR PRIVATE SHOWING
LOCATED IN LA PINE, OREGON
DELIVERY AVAILABLE ANYWHERE ON EARTH - for a fee
Ovrlnd Rd
So he wants someone to pay $67,500 because it has a nice HAB? No mention of the condition of the vehicle underneath it. Having owned MANY military vehicles I'd be more concerned about whether it could actually get to where I wanted to go rather than what I'd be sleeping in once I got there.
Petersmithinak
