L track for mounting heavy items to exterior of camper?
Baumer
Hi there,
I was wondering if anyone has used L Track or E Track to act as a mounting surface on the side of a camper. Im thinking for things like hi-lift jack, shovels, maxtracks, jerry cans, awnings, etc.
It seems like a great way to have a flexible mounting surface, but I am not seeing much on google. Has anyone here tried this approach?
Herbie
Rendezvous Conspirator
CampervanCulture in the UK sells a kit for the VW vans.
I've done something similar but only for lightweight stuff (traction mats and shovel) on my Astro van.
5VrUzuHEGDIW2F2cGftoO6IAFaFW4yTK-sdpFj56Nwj4gZD0J74EImXFx9vcTbf9kIDH0xofmHX-8ZpFmRT0w93gs49sAB4DHXBrhBdzJggdY58lOuZXUE-ve-sWZ8Cio1nEx3mJIhLXMO9JgCDWQ5PlMW9t-Q430Fdn-Jjf4pkdvhjhuTr7q3mjvhPYdlbyFbHoAlBq10gFyy9fo00luUL_jVSaMlo8PKESrvI1h6kmb1XtnP1XfB2Nthwfl24IesLi9L3nCBS9uBJizd7gaaHB5juDFIalL_yxUkjN4zGTKP_xSz10txqXh8OF9L4piO9O7vOdLClK_p5nJWEkKqCQxlq2m2t_xr0tCVMFWXW-1S7VGBsG1aflpbxaqoWnYnnLsieUn5srbPmwk-WXrxtAhZEyRP7vDdAf8RWexyTgD1-IsHU9th0LaSIvGBIVfbL6se6WTm1cSWGv5lkLfNHBvZK1KCVAa1v1pviSSdzd8Spn-VkumWQ_enx3oi_LQkSKapUCI7ktAL7r7RQb565rcRhwbQW-BCP7EHcCpHQxRq_IMDfmEIwSvCjDI6lQh_N16JflkSGb2fWZ8IvqlKOGoeCY7oTVqEoeNaxNHtuNXblswM2IwAsN63SCSXan3iCQIacml_aGRLvHfUdGfuUr6BaZyR2b_Q=w600
Roverini
I am wondering the same thing. I would like to use L tack on the rear doors of the van to hold fuel cans or other stuff depending on the situation. It seems a perfect way to have a flexible mounting system with very low profile when it is not engaged in holding things. Here is a picture of one set up using what appears to be L-track. There are bolt fasteners which could be used to lock the Jerry can holders to the track. I see the L track used in vertical applications for seat belts so it seems like it should work. One should probably use a backing plate or tie into the door frame for support. a 20L can will weigh a bit over 40 lbs.
project13support
