ini88
300Tdi engine with all ancillaries with 78k when taken out of a 1995 Defender.
Manual injection pump
Radiator/Intercooler
Radiator frame
Shroud
Fan
Rubber top sound damper
Starter motor
Turbo
Down pipe and full length exhaust
All brackets for filters etc.
Coolant reservoir
Engine brackets
R380 transmission + bellhousing
New clutch fitted
1.4 transfercase
Tdi crossmember
Wiring harness
If you don't need the 1.4 transfercase let me know to make it cheaper.
$7000 obo - Located in NJ. I can pallet everything up for you if you arrange shipping.
Radiator frame
Shroud
Fan
Starter motor
Turbo
Coolant reservoir
Engine brackets
New clutch fitted
1.4 transfercase
Tdi crossmember
Wiring harness
