Land Rover Rear Door Cooker Housing
gchinsr
I have a Mobile Storage System rear door cooker housing for Land Rover 90/110 Defenders. Housing bolts to rear door, and closes secure with a latch. There is a lock, but cant find the key. I will contact MSS and see if a generic key is available, and can forward on to you. There is a shelf which can be used when not cooking, while the cooker housing remains in the stored position. There are built in wind guards to protect the sides when cooking, that fold flat on the rear of the housing for storing away. There is a wind guard for the front, with low, and high positions, which is loose, and stores in the rear of the unit when closed. There are a couple dings, scratches, and a few tiny spots of surface rust just starting These items are cosmetic, and will not effect the unit in any way, and is in very good condition, and will last for many years of use. A little 3M Scotch Bright, or super fine sand paper will easily remove this, and you can paint to match your vehicle. It could be used on any vehicle with a flat rear door surface, for it's 22"x12.7"x4" dimensions. Asking $175 plus shipping from Los Angeles. MSSClosed.jpgMSSShelf.jpgMSSSidesOnly.jpgMSSLowGuard.jpg
ersatzknarf
lost, but making time
Good luck with the sale, Greg.
If anyone is looking for a recommendation, I have purchased several items from Greg and highly recommend him.
TangoBlue
American Adventurist
That is pretty cool item; looks stout too. Solves 2 issues at once - storage and application. Slick.
gchinsr
There is also an opening for a gas line on the left side of the box. This lets you hook a quick connect to the cooker so you dont need to always remove cooker to do so.
Goldenbora
