Stumpalump
I had a malfunction.
Rebound clips severely limit droop and since I'm adding two of my old leafs into the new ARB spring pack I had to weld them longer.
One clip is on one leaf and the other on the next. That's just how it worked out with the leafs on hand. Without the clips or the bolts removed you can get crazy flex out of a leaf spring but then they break. Longer ones are the compromise between good flex and longevity.
New pack as shipped on the bottom and modified new pack on top.
With one side on I'm 3/8" taller on that side. Back to the grind to finish up the other side.
