Madoxen
I have been Giving lots of thought to the different areas of my build and reading all the ways that you guys are coming up with to overcome the obstacles in your path. One area that I keep coming back to is the lift for the back of the truck for the spare wheels and bike etc, I like what Sitec and B85 have done with either winch set up or Block and chain, but I was wandering if there is another easy form of lifting mechanism for getting the platform up and down.
So long story short I have been dismantling the New Donor Actros 2657 for all of the swappable parts, and had to lift the cab up for the umpteenth time, while doing this I was watching the Hydraulic cab locs open then the ram extending and lifting the cab up, all off of a socket and lever being pumped left and right, “Light Bulb in head starts to blink” could it be possible to use the twin Hydraulic rams mounted to a cam of sorts to both close/lift up( so that the ram is rested in the closed position and wont rust or get damaged ) into the hydraulic cab locs which will loc/fix the platform into place then with the switch of a lever and a few pumps you unlock the cab locs and start to send the platform on its way down. There is also the possibility to use the electric cab tilt motor for the rams off of a recently written off UD450 flatbed I have rusting in the yard, the electric tilt pump has the fall back of a manual pump if it ever gets an electrical fault.
Any thoughts or suggestions? is it possible, has anyone tried this before.
