nitro-gear
Supporting Sponsor - Differential & Axle Parts
This Rig Was Already Running #NitroGear 4.88s - but you can find the same lift kit that's shown here on JustDifferentials website LINK BELOW Shop Suspension Packages: https://www.justdifferentials.com/JTO... Features & Benefits: Bolt on Super Deluxe Suspension Kit includes: -Front Torsion bars, Med-heavy load (adjustable height) -Progressive Rear Coil Springs for comfort and increased load capacity (optional heavy load) -Powder-coated 20mm Diff Drop kit -Nitro extended travel Ball Joint Style Upper Control Arms (UCA's -Extended length Icon Vehicle Dynamics shocks, valved and spec'd spedifically for this suspension kit Choose stage: Stage I: 2.5" Diameter Internal Reservoir Front, 2.0" Diameter Internal Reservoir Rear Stage II: 2.5" Diameter Remote Reservoir Front & Rear Stage III: 2.5" Diameter Remote Reservoir Front & Rear, with *CDCV adjusters *The ICON CDC Valve is an externally adjustable valve that restricts oil flow into the reservoir which creates 10 levels of compression damping force ranges. Options/ Upgrades: -Front & Rear Timbren bump stops -Rear Adjustable upper Control arms -Billet Rear Adjustable lower control arms by ICON #Lexus #LX470 #Overland #4x4 #OLAF #SendIt #IconVehicleDynamics #LiftedLexus
