articulate
Ok, we've discussed which SLR to get, wide angle lenses, great sunsets, and trail blockage.
1. Does anyone here use a light meter? If so, do you use a spot meter or an ambient meter? Why? Do you use it much?
2. If you don't use a meter, do you just trust the camera...or have you learned to judge the light?
I currently shoot a Canon Rebel T2, and most often with color transparency film like Fuji Provia and Sensia. The built-in meter on this camera, as I've learned after all these years, over-exposes too much for my taste. I believe that built-in meters are also ambient meters....so I'm considering a spot meter.
On a bright sunny day, with ISO 100 fim, aperture set to f/16, my meter will think that a shutter speed of 1/60 is appropriate (but the rule of thumb says as close to 1/100 sec as possible). But that blows out the bright stuff too much, like this:
On a bright day, I've learned to manually set the exposure to the equivalent (when I want a different DOF) of f/16, 1/125 sec with ISO 100 film.
This shot is about 10:30 in the morning, bright sun with no coverage:
I swear that sky is not altered with photoshop. I think the exposure is perfect.
So, fine. Mid day with bright sun I can handle. So, I think I want a meter for when the light is different. Particularly during storms.....
I suppose I don't necessarily want to know which brand of a light meter you have. But your thoughts on using one. Does using one sort of train you by osmosis to read the light with your gut?
Thanks for your input.
Mark
Mark
