lightforce 240's vs cibie
expo95taco
that do u guys think i should get? im looking at cibie super oscars and the lightforce 240 blitz lights? how the light output with these? post up pics if you have any. ive searched and found the light thread, but not to many pics on there from night time
bigreen505
The only person I know who has experience with both sells Cibie. The big difference between them is build quality and materials. The Lightforce lights are light weight plastic while the Cibies are very well made, somewhat heavy metal and glass. The Lightforce lights allow you to control the size of the cone of light with a zoomable reflector, and to some degree with protective filters. The Cibies have a very well made, precisely ground glass lens. What this means is that the Cibies control the light dispersion more, but they are what they are. With the Lightforce you can control the general spread of light, but not things like cutoff.
While the description makes the Lightforce sound comparatively cheaply made, it really is just a different way to make a light. The Cibies, being heavy, require a stronger mounting. The enclosures can handle heat from high wattage bulbs very well, but you are more likely to crack the lens on a water crossing (hot glass, cold water). The Cibies have a replaceable lens reflector if you crack one.
Do a search for Cibie and Lightforce lights on the Australian expedition forums (exploroz is a good one) as there is a pretty good sample of both lights in use there.
I've always been happy with Cibie lights, but I don't have much to compare them too.
expo95taco
thank uobiggreen505.....k im going to look into the other forums, but if anyone else has any experience with these is appreciate all ur info. or even if you have just pics of the light output on the lightforces or the cibies, all help is more than welcome
I have two Lightforce 240s (HID not Blitz) and three Cibie Super Oscars (two spread and one spot) on mine.
The Lightforce HIDs are brilliant on road, virtually useless off-road. They are set up for distance and the light output is huge, so that's fine.
The Super Oscar floods are nice off-road, plenty of spread, no hot spots, good lenses. They're also OK as on-road high beams up to about 70 km/h.
The Super Oscar spot is rarely of use, not recommendable.
Construction-wise the Lightforce are no problem. The Super Oscars fell to bits on corrugations, and needed top screws as a minimum, and have since had the bases bolted to the housings as well, as the rivets were rounding out.
If you can only fit in two lights, I'd suggest Lightforce set up for more spread than I have.
Schattenjager
My LightForces are about the only thing to survive a frontal collision that totaled my Tacoma. They now live on my Land Cruiser. No metal/ glass light would have made it. I love the tunability and lens options too.
xander69
