Jonathan Mellas
Former Military Stewart and Stevenson LMTV converted into the ultimate off-road and off-grid tiny home.
As featured in FourWheeler Magazine.
Built for extended stays off grid, this rig has just about everything you need for life on the back roads. It draws quite the attention around town and is sure to give a don’t F with you vibe wherever you might find yourself staying.
Inside is a comfortable, flexible, and open layout with a full size kitchen, beautiful wet-bath with a composting toilet, and a flexible dinette to full-size bed area.
With 920 watts of solar and 420ah of Lithium battery power, this beast is good to go for days.
The truck only has 18,000 miles on the freshly tuned Caterpillar 3116 engine and Allison 7 speed automatic transmission. Truck is 4x4 (obviously) and is ready to hit the road and go far off into the wilderness once again. READ BELOW for all the upgrades and options that I’ve put into the truck. It really is such a dream rig and just needs the right owners to take this into the unknown.
TRUCK AND CAB
1997 Stewart and Stevenson
Road Legal Kentucky Title
NO CDL REQUIRED
CAT 3116 Turbo engine, 18,000 miles
4x4 Allison 7 speed Automatic Transmission
47” tires (80-90% tread)
1 full size spare
4 blind spot cameras with 9” screen
CTIS (Central Tire Inflation System) works well
LED light upgrade
New Alternator and Regulator
New water pump belt
New alternator belts
New Rear Sway Bar Bushings
New Fuel Filter
New Fuel Separator
New Thermostat
New oil and filter change
New inner timing cover (air compressor bracket bolts have locktight on them)
All grease points recently greased
New rear differential oil
New Fan Solenoid
Interior cab light
Insulated ceiling with Rustic wood paneled ceiling
Furrion Tankless Propane Engine Heater (for cold starts to protect engine)
New TRIMARK locking handles
New metal window cranks
Passenger side blind spot semi mirror
Upgraded racing seats
Gun turret is sealed and monsoon proof
Rubber white paint on truck roof (sealant and keeps cab cooler)
Gray Raptor liner paint on cab
Custom clear defrost panel (more visibility)
Air filter is in good condition
Batteries all tested good (1 new)
20 Ton jack with 100’ air hose connecting to trucks air supply
All extra fluids come with the truck (including air line antifreeze and diesel winter fuel additive)
Hydraulics in good working condition, no leaks. The Cab lock and suspension hydraulic seals have been replaced.
Newly replaced spare tire hydraulic cylinder
Quick Fist Clamp tool mount
Very little rust on truck.
Truck weighs 22,000lbs approx
Top speed is 55mph
HABITAT
76 gallons fresh water (combined interior and exterior) with heated tank pad.
41 gallons gray water (combined interior and exterior) with heater tank pad.
Furrion tankless propane hot water heater
20lb propane tank
420ah Lithium Lion Energy battery bank
920 watts BP Solar
Victron Energy 50amp Charge Controller (fused)
3000watt Renogy Inverter (fused) with remote on/off switch
2 Deluxe MaxxFans (in/out, with remote)
Dometic 95L Dual Zone CFX Fridge/Freezer (on drawer slide w/lock
Duxtop 2 burner Induction Stovetop
120v wiring (with breaker box)
3 GFCI outlets in kitchen
2 outlets with extra USB ports in bedroom area
4 USB ports in kitchen
12v lights separated on dimmers with adjustable color brightness
SeaFlow water pump and accumulator tank
Large dual Stainless steel sink
Full size pull down faucet
Ratcheting Paper towel holder
Spice rack
4” high density foam mattress/cushions with removable/washable coverings
Large flexible dinette/couch/bed area
Full size bed 50”x75”
Ample amount of locking cupboards and drawer storage
Waterproof vinyl flooring (with sealed edges)
Emergency Exit escape window
3 tinted windows with screens
Dual option locking RV style door with screen door
Medium sized desk
Coat rack near entrance door
Large 8kw Diesel heater (connected to main diesel tank
New blackout lined gray curtains (not in pics)
16x30” mirror (not in pics)
WETBATH
Nature’s Head Composting Toilet
Waterfall style shower head with handheld flexible rinse hose
Tilted floor towards drain
Tiled with flexible grout, no leaks
Faucet and sink
1 MaxxFan shower vent/light
Dometic Waterproof toilet paper roll holder
Electrical GFCI protected outlet inside wetbath
Interior height is 6’ 3”. Box length is 16’ total. Truck Length from bumper to butt is 25’. Very well insulated and even when parked in full sun on a hot day my pets are able to stay cool.
Professionally appraised at $118,500. Will provide document for loan or insurance purposes upon request.
TRUCK AND CAB
NO CDL REQUIRED
1 full size spare
LED light upgrade
New water pump belt
New Fuel Filter
New Fuel Separator
New Thermostat
New Fan Solenoid
Interior cab light
Top speed is 55mph
HABITAT
20lb propane tank
920 watts BP Solar
Spice rack
Medium sized desk
WETBATH
Faucet and sink
