aslostasyou
Looking for some feedback here. I've dialed my Discovery back from a heavy wheeling rig to more of a destination vehicle. It's stripped and still really beefy but I want to use it for more long distance type stuff rather than hard-core offorading/wheeling events. Which brings me to the dash design. It's currently gutted and I plan on building a template out of wood to turn into aluminum for the final product. I'm willing to take time to make some intricite pieces, that's part of the fun and an excuse to learn how to tig weld.
I've scowered the net and I can find plenty of "race" dash ideas but they all look too plain or cheap. I don't want to stick a sheet of aluminum in there and call it a day.. I want to build somethign with some class and style and still have functionality. The Tomb Raider Defender dash comes to mind as an idea. I have some checkerplate that I can use for accent pieces as well.
Starting on the drivers side I'd like to build up a gauge cluster similar to the one in the photo. I plan on voltage, temp, fuel level, oil pressure, air fuel and rpm. Speedo will come from the 276c Garmin center mounted so drive and navi can reach it with ease. Main switches will go on this cluster as well, ignition, push button start, fuel pump, etc..
I have a CB radio and HAM that I am unsure if I should integrate into the center console I'm building or, if I should put them up high between the roll-cage frame. I'm going to build a secure console similar to a Tuffy aft of the parking brake since the Rover plastic bits have been pulled. Do you think CB, CD and HAM would be too much in a single spot? There is quite a bit of room from my measuring. Do those really need to be forward facing? Part of me says yes for tuning while rolling... Thoughts?
I plan on building a "center" of the dash that will come down at an angle towards the dog box and look clean to break apart the driver/pass sides. Behind this will sit a Flex-a-light Mojave heater pointed up towards the windshield integrated into the top of the dash.
Not as detailed as this obviously but you get the idea.
On the pass side I plan on building an oh-**** bar and a locking glove blox in the lower portion.
Aside from that I'm open to suggestions, thoughts or ideas from the overlanding crowd. What do you use all the time that you wish was in arms reach? Winch switches, lights, etc? How would you mock it up? Is wood a stupid idea? Things like that...
Thanks everyone!
Thanks everyone!
