Looking for this...
blakesrover
Mantec bolt-on diff guard
Thanks for any info.
~Blake
One4adventure
Are you hoping to slow down people following you when that thing falls off?
I have picked up a few of them on trails:coffeedrink:
Cheers,
Chris
blakesrover
i"ll have it tethered to the axle when it does fall off:sombrero: But I can be sure none of the pumpkin will be coming off with it as "could" happen under tack welds.
So can I assume you have a few extra lying around not being used?
~Blake
bperry83@gmail.com
Snagger
The QT Services guards are better. Anything from Mantec seems to rust within weeks. The QT guards are more securely attached and also protect the underside of the diff and the track rod.
lake_bueller
Check out Lucky8llc.com for some good parts. My previous DI had Equipe front and QT rear diff guards. I sold them when I totalled my truck because the new Disco had Southdown protection from front to back.
lake_bueller
word on the street Luck8 is looking into because they no longer are getting any equipe in
Just call Justin and get the real scoop. He sometimes has a hard time getting parts if they're not in stock. He only receives freight from Europe when he needs enough stuff to justify the cost.
mud ruts
This have changed since sept. Lucky8 now sells mantec and does weekly orders to the UK for parts.
Chris
benlittle
These are out of production according to Mantec. I tried both AB and BP a few months back and neither had it.
WoldD90
Rovers North, Atlantic British, Rovertym and a few other carry several versions... The bolt on versions are nice, since you can take them off and clean out the dirt.
When you put it on, use some RTV or The Right Stuff, so you will know it is sealed on there.
Goldenbora
