lower costing CPES to save your wood
two
Rhino Linings Deep Seal Epoxy with Hardener 3163with 10%-15% thinner. This combination will yield a 100-150 cps mixed viscosity (water) The hardener is cycloalphatic type which will also yield a water clear finish
I have been holding off getting started on my builds I need a few more Modular fiberglass building components. There main thing is underground bunkers .So this is there busiest time.
So I planned to coat my plywood with Clear Penetrating Epoxy Sealer.That way I'd be doing something.The cost was very high. So I talk to Mat @ thefiberglassstore. Was told all CPES is Rhino Linings Deep Seal Epoxy with Hardener 3163 with 10%-15% thinner.So why pay for someone to put it in there own can & name? So now I will pay $30 for 1/2 gal of Epoxy with Hardener. They don't sell it but someday will do a Modular fiberglass component building kit teardrop trailer for them.
So if you are buying this the tec. name.
jwiereng
I found your OP was difficult to read. I have edited you post. Please let me know if it is incorrect.
This combination will yield a 100-150 cps mixed viscosity which is almost the same as water.The hardener is a cycloalphatic type which will also yield a water clear finish.
I have been holding off getting started on my builds because I need a few more Modular fiberglass building components. Their main thing is underground bunkers, so this is their busiest time.
I planned to coat my plywood with Clear Penetrating Epoxy Sealer. That way I'd be doing something. The cost was very high. I talked to Mat @ thefiberglassstore. I was told CPES is Rhino Linings Deep Seal Epoxy with Hardener 3163 and 10%-15% thinner. Why pay for someone to put it in their own can & name? Now I will pay $30 for 1/2 gal of Epoxy with Hardener.
They don't sell it but someday I will do a Modular fiberglass component building kit teardrop trailer for them.
If you are buying these products, this is the tec. name.
