LR3 blower motor?
unseenone
Pull the cabin air filter out and make sure it's not gummed up or wet. If you're not going used, try british4x4outfitters or landrovermerriamparts.
aw990200
Mine was doing the same thing. I just pried the squirrel cage(?) off the spindle carefully, and then cleaned the brushes. I slid a flathead screwdriver between the squirrel cage and blower motor housing to use it as a pry bar. Just make sure to not damage the squirrel cage, otherwise you'll have to buy a whole new assembly. Reassembled and no more squeak. Plug the motor back in to check it before you completely reinstall just to make sure you cleaned it well enough.
TexasTJ
Climbing Nerd
Do you have any pictures.
aw990200
Sorry. I don't, but when you remove the squirrel cage you'll see that the brushes are what contact the spindle. It should be pretty dirty, so just wipe it out really well. I didn't use any liquids or solvents because I didn't want to get any moisture inside the motor.
flipstick
