LR3 rear seals by differential?
flwoodsman
I just discovered I have a leaking rear seal but im having a brain fart because I can not remember the name of the seal. Its located on the right rear axle where the differential housing meets the axle. Ive tried searching for "lr3 rear axle seal" but it always brings up the seal near the hub area and the leak is at the other end of the axle. I know its not the pinion seal. I have a pic but havent figured out how to upload from my phone yet. Can someone point me to the right part name/number?
flwoodsman
Pic
unseenone
Axle seals... More than likely there is a reason they are leaking, worn out bearings play damaging them, over filled diff, plugged breather. Let me know if you want to get something more than seals.
How many miles on your diff, maybe worth replacing it.
Side Shaft Seal (a) TZB500050ee
Side Shaft Seal (b) TZB500050
Picture of seals here.
lkretvix
