brickpaul65
I have searched around and have found a few threads on various forums where people have discussed fluid flushing (both old school drain/add/drain/add and the flush systems) as well as replace the pan and filter adding new fluid.
Unfortunately I have not seen any post really discussing the results or people saying they have done it. A few people siad everything was fine. There just is not a wealth of information out there.
I know the transmission is a zf sealed unit. The fluid is recommended to be changed at 150K. The question I have is are there advantages to doing it sooner? I just struggle with the concept of more than 100,000 miles on a tranny and not just changing the fluid. I know technology has improved etc.
Basically, I have 103,000 miles on my '06 LR3 and would love to keep putting them on. I am not having any issues. I was just considering preventative maintenance.
Has any one done this? If so did you use something like a powerflush option (which fluid did you refill with) or manual fill (fluid choice)?
I would also like to replace the fluid in the diffs and tranfer case. Any fluid recommendations? I used royal purple in my two wrx's.
Thanks guys. Sorry for the post but I just could not see a whole lot of results discussion.
