M.U.T.T. Trailer for SALE - So Cal
AVO
FOR SALE: M.U.T.T. Trailer - $4000 or Best Offer
Interior Bed Size - 4x6
Two weather sealed side boxes with locks
#3500 lb load rated springs
5 on 5.5 bolt pattern (this can be any bolt pattern to match your vehicle)
13" electric drum brakes
Brake-a-way electric brake controller with mini gel battery in custom box that displays battery condition
Custom made axle
in current configuration this trailer weighs 1200lbs (GVWR is 3500 so you have 2300lb load capacity left.)
Tongue lock box houses - two yellow top optima batteries, 1000W inverter, twin weather sealed house outlets, 16 weather sealed switches, digital battery life info panel. There are four red LED lights in the bed, four super white LED lights under the trailer, two LED brake lights, four LED marker lights (2 red/2 amber), each box houses an LED light inside. Passenger side box houses a twin burner 50,000 BTU propane stove with a 2.5 gallon LPG bottle.
Tongue is a custom Caboose theft resistant version utilizing a Couplemate Hitch with 360 degree rotation and urethane block to reduce load shock
Rear steel tailgate with lock tabs and the forward upper shelf allows easy carriage of 10x20 EZ-Up
