M101A2 Expedition Trailer
dmcasshooter
Military surplus purchased military trailer, titled in state of Washington.
Features:
Camper shell built with 2x4 wood covered with plywood, fiberglass reinforced plastic (FRP) panels for waterproof exterior and membrane roof. Lockable passenger door in rear, rear compartment can sleep two adults (foam mattress pads included). Expandable rooftop tent sleeps 3/2 kids or adults, has aluminum adjustable ladder that drops off tent for easy access. 15 gallon water tank with pump, switched on and off to save power, when on sink handle activates. Unit built off ac converter powered by 2 6 volt golf cart batteries (or 12 volt car battery, not included in sale). Can be run off shore power and batteries can be charged via inverter when running off shore power, interior/exterior lights, power vent fan and water pump run off upgradeable fuse panel. Slide out sink stove combo to side of trailer under an ARB awning, each side has lockable storage compartments. Each corner has full adjustable stabilizing legs, 2 inch receiver hitch in rear.
Hitch is pintle type, with integrated surge breaks, original to M101 trailers. Taillights are converted to 12 volt and are on a four pin connection.
Towed crosscountry last summer with 1/2 ton vehicle with no issues, emergency spare included (older tire/rim) for short term use. Selling to start next project.
Trailer located in Adams TN asking $3500
dmcasshooter
Weight
Original weight ticket was for 1680, but that was without RTT and few other build items. That said probably closer to 1800/1900 lbs.
Thanks for the question
