M1101 Needs a new jack
WarPig BBQ
Hey guys, my jack is in bad shape. Has anyone found a good replacement with a wheel that will mount in the original location?
RagnarD
What is wrong with it? You can find parts to repair some things.
I believe the wheels are bolted on so you should be able to re-use the caster on a new jack.
Just go to e-trailer and start browsing. You may need to buy the jack separate from the pipe mount so you can get the height correct and to make sure it fits when stowed.
WarPig BBQ
Ok thanks Ragnar. I looked at it last night and the only thing in bad shape is the wheel. I doesn't want to spin. It is pinned on so I'll look for a replacement. No need to spend money on a new jack if all I need is a wheel.
Houie
