M1103 Humvee trailer FS -
4x4freedom
Hey Guys,
I have a Silver Eagle Flat deck trailer that I was planning to use for the basis of a camp build but my thoughts have changed and I'm going another direction. Here is a copy of the ad posted on Craigslist. Trailer is in Vancouver but I'll be heading down to Nevada the second week of March and can deliver it along the way. Let me know if you have any questions - thanks for looking.
Looking for $1150.00
Tim
For sale is a 2006 Silver Eagle Military flat bed trailer.
This trailer is fully legal, licensed and plated and ready for the road. Works great for ATV's, Motorcyles etc and can be easily converted to many uses. Trailer was never put into use by the military and spent most of its life in the dry desert air. Tires are basically new and it needs nothing. I've towed it behind my Nissan Xterra as well as a full size pick up and it tows flawlessly. Has fully working trailer brakes including individual wheel park brakes.
Trailer is located in Vancouver and I can arrange delivery free of charge - within reason. Email me with any questions.
Click on the link for more or see below for the manufacturers specs:
Thanks,
Tim
This trailer is in as-new condition and features the following specs:
General
Maximum Vehicle Weight 4200 lb (1905 kg)
Curb Weight 1280 lb (580 kg)
Maximum Payload Capacity 2920 lb (1325 kg)
Hull Unitized body construction using aircraft grade aluminum and chromoly steel
Dimensions
Overall Length 132 inches (335cm)
Overall Width 85.6 inches (217 cm)
Overall Height 45.5 inches (116 cm)
Track Width 72.5 inches (184 cm)
Drawbar Length (from axle center to eye center) 93.2 inches (237 cm)
Drawbar Eye Height 29.5 inches (75 cm)
Deck Height 34.5 inches (88 cm)
Ground Clearance (Laden) 16 inches (41 cm)
Running Gear
Suspension Type Fully independent progressive rate trailing arm suspension
Axle Tubular steel
Spring Media Progressive rate torselastic rubber chords
Shock Absorbers Telescopic, direct acting, one per wheel, HMMWV compatible
Wheels 16.5 X 8.25, two piece steel, HMMWV compatible, 8 on 6.5 inch bolt pattern
Tires 37X12.50R16.5 Goodyear Wrangler M/T, with 30-mile runflat inserts, HMMWV compatible
Brakes 12 inch x 2 inch free backing hydraulic surge brakes with automatic breakaway actuation. Independent lever-operated left and right side mechanical parking brakes.
Electrical System 24 Volt DC sealed lighting system with blackout convoy lights, 12 pin connector plug mates with HMMWV
Performance
Max Speed (Primary Roads) 55 mph (88 kph )
Max Speed (Secondary Roads) 35 mph (56 kph)
Max Speed (Off Road) 20 mph (32 kph)
Departure Angle 39 degrees
Turning Angle 80 degrees
http://www.silvereaglemfg.com/military/flatdeck.shtml
tbnd88
