M416 questions
Ok I fixed the bearings and now I on to the tail lights. Is there a conversion kit out there that I can keep the original light housing, maybe change out the inside and add a new four prong plug? Thanks:)
Also does anyone have a source for M416 safety chains and new tires but want to keep the original style.
sgv209
All you need for the lights is to get new bulbs. I took the 24V ones to the NAPA store and asked for 12V versions, and I replaced the bullet connectors with a 3 pronged delphi connector from McMaster.
I bought brand new tires from cokertire.com
Snowrydr01
like above, just brought the original bulbs to autozone and got 12v ones.
as for the wiring i got a $5 4prong plug from autozone while i was there and some bullet connectors and just plugged then in the appropriate female end.
Check my previously started threads and there is a wiring diagram with what plugs go into what number
flipstick
