m416 tire load rating question
msand1977
I'm about to change the tires on my modified m416 trailer to civilian tires. I'm using Omix-ada 16725.01 replacement rims that have no rivets to worry about. To keep the tires as close to stock as possible I was thinking of going with 225/75r16 or 215/85r16s. I cant seem to find an all terrain that comes in load range C most are E and some are XL. I'm worried load range E will be to stiff and bouncy for my trailer. Does anyone see an issue going with XL? My trailer weighs max 2000-2500lbs loaded.
Thanks
Matt
old_CWO
As long as the tire load rating for the pair is sufficient for the gross vehicle weight, you are fine.
lkretvix
