M416 Tires
I have original rims for my M416 and was wondering if there are other options for tires. If anyone knows any different tires you can use with these rims could you please post. Thanks
dirty Bakers
Conservative
I have not found a tire that you could purchase at a discount tire that will fit your rims, any sixteen inch tire will fit but most newer style tires require at least seven inch wide rims. The "original" type tires are still available along with some bias-ply mud snow tires. Try looking up NANCO tires. Heavy duty trailers tires will work also.
97tjguzzy
if a 235 will fit on a 4.5" rim and it is supposedly 9.7" wide, what do you think of mounting a 255x85x16 on the stock rim. I have some sitting in the garage and I am planning to try it, but I cant decide if i should go ahead and put them on wider wheels.
Clemtiger84
