OverlandKyle
Hello.... After adding my RTT to my Bantam, it sways quite a bit because the suspension on there is original and is sagging bad so I'm going to replace both leaf springs, u bolts, the shackles, the bushings, and the eye bolts and while I'm at it, will also get u bolt plates that have the shock mounts on it already.... Now, as I don't have a welder, I would need to find upper shock mounts that are bolt on... I've heard the m416s shock mounts will fit in the frame and can be bolted on.... I've looked for places that sell them and I can't seem to find them (g503, rfjp, DandL)
Any leads?
Any leads?
