Nivel Egres
Living the the NYC is hard. Parking in the NYC is even harder. So, my vehicle choice is the tallest midget of them all - Honda Fit. Had it for a year and hate it with passion, but my choices are limited - sub-compacts are literally twice cheaper to park then an SUV or full size car. The only reason I own a car is to be able to reach rocks and mountains, so most of the 45k miles are accumulated on road trips of various duration. Truly, I wish there are SUVs of ssimilar dimensions (I heard there are, but nobody imports them into the US), but at the moment Fit is the best of my choices (IMHO).
Now I would like to invest a little into making the car a bit more comfortable for road-tripping and could definitely use a bit of wisdom and advice. Here is what I would like to change about the car, in no particular order:
(a) The ************* gas tank is the size of the mouses bladder - 10 gallons. My previous car, a Volvo, was doing 22MPG and had a 25 gallon gas tank, this thing is supposed to do 35MPG and has a 10G gas tank. Something does not compute there. Plus, IRL I get closer to 30 and with the bouldering pads on the roof rack I get about 22. So any extended drive requires numerous gas station stops and I am always nervous about running out of gas.
-- Is there a way to install a bigger tank or install an additional one?
-- Alternatively, is there a circular gas can to put into the car instead of the spare tire?
-- Alternatively, is there a gas tank mount for the rear gate? I'd be ok with a 2-3 gallon spare tank, no?
(b) Make it just a tiny bit better off road. I am not planning to ride the dunes or cross streams, just want to be able to feel a tiny bit more comfortable on gravel and dirt roads which frequently lead to rock climbing destinations.
-- Can I install slightly bigger wheels to increase the road clearance?
-- Also, maybe there a suspension lift kit that would make the car sit just a tiny bit higher?
-- Would I really lose something by changing the fancy alloy wheels to regular steel ones with a bit more sidewall and slightly more thread?
(c) I have a 42" x 63" roof rack that usually houses my bouldering pads, I would love to mount it directly, without the cross bars using quick-release type fittings.
-- How difficult/bad would it be to ask someone to screw brackets directly onto the roof and waterproof?
Any other ideas or personal experiences of travelling in a micro-vehicle like that are welcome!
