Making a little progress on the zj
intothewild
Finally had some free time yesterday so I installed the 2" bb, with the isolators left in it netted about 2.5". Got four new shocks installed and I replaced a control arm bushing that was destroyed. Got some quick discos today, and still have a new steering stabilizer to install. So next time I have some free time I will get that done.
Here's how she sits right now.. Still looks fairly stock, even with the 31s. But this isn't a rock crawler, so for now I'm content with the size and can focus on strengthening the weak links next.
4lowdean
Looks so 'clean' and 'unmolested' compared to mine.
One thing you may want to look into is the heavy-duty cross member from Rusty's Off Road. It will replace that rather flimsy stock cross member. With the longer wheel-base on the ZJ you may bottom out going over small 'hills.' It also lowers the transmission about a 1/2" while giving you another 1/2" of ground clearance. That little bit of drop helps with the rear dive-line angle when you're at the 2.5"-3" lift mark.
As for other "weak links", the front steering on the ZJs is rather flimsy. On my 4.0 I swapped to the tie-rod and drag-link off a V8 ZJ and that helped a little but even that started to bend. There are a few after-market ones out there that are worth doing once and being done with it. I run the Rusty's tie-rod on mine. I wish I could/would have sprung for their entire steering set up.
I am not *trying* to pimp Rusty's Off Road, but truth-be-told they are one of the few companies out there that still make anything worth-while for the ZJ. :smiley_drive:
K2ZJ
There are times I wish I stayed with a bb and 31s. I love the look and how drivable it is. Looks good, don't have little mans syndrome over it.
jeep-N-montero
I would rather drive my 96 on 33's than my 97 on 35's, I may even be swapping some stock axles back under my 96 with some 31's in the near future.
iStan814
