Man-Powered Recovery
carbon60
I just watched an episode of Dirty Jobs (Discovery Channel) where Mike, the host, recovered a 11,000 lb Humvee using 6 snatch blocks, a *lot* of rope, a tree and 10 warm bodies. (My counts are not exact.)
That is seriously cool!
Anyone have a link to an explanation of how to figure what's required to do that in terms of blocks and bodies?
A.
AFBronco235
Crew Chief
Look up FM 20-22. Its the same manual that lets the army do what you just saw.
Its basically a matter of mechanical advantage. They traded distance for pulling force. In other words, in order to pull a 5 ton vehicle 20 ft., they had to move those 10 warm bodies about 200 ft. or more.
taugust
Its fairly simple. If you have, for example, three snatch blocks attached to the tree, and three to the vehicle, and one rope that looped through all, you get a doubling of the pulling force every time the rope changes direction. Using round numbers, say those ten guys together pull with a combined force of 1 thousand pounds (not out of line. I just took a test where I had a measured standing horizontal pull of about 150 lbs.). That means that anywhere on the rope, there is 1000 lbs of force. If the other end of the rope is attached to the vehicle, there are the equivalent of 7 ropes pulling at 1000 lbs each pulling on the vehicle or 7000 lbs. That should be more than enough to roll a vehicle back onto its wheels.
Put another way, the first pulley has 1000 lbs on each part of the rope that passed through it (the part that goes to the guys and the part that goes to the first pulley on the tree). That means that the first pulley is tugging on the vehicle with 2000 lbs. Each additional pulley attached to the vehicle pulls with 2000 lbs. and the free end attached to the vehicle is 1000, or a total of 7000 lbs. Make sure the tree can handle a 7000 lb tug (attach the pulleys low on the trunk) or use more than one tree.
As mentioned before, the pulling guys would move a long way for very little movement of the vehicle. That is the nature of mechanical advantage (in nature :) ).
Typed with my thumbs
Edit: I assumed a rollover, but if the vehicle was on its wheels, even less force would be needed, unless they were tugging it up a hill. An 11000 lb. vehicle doesn't need that much to get it rolling.
carbon60
The Humvee was buried in sand to pas the hubs.
I will look for that manual, thanks.
I was looking for how to calculate the required manpower.
