Material question
BigBrokenZJ
Been looking into building a drawer and tray for the back of the truck. I’m obviously looking for that happy medium between strength/durability and weight.
It seems like most drawers are made of 3/4 ply, but I wonder about the long term durability. I’ve had work trucks with truck vaults and they always seemed to hold up great, but they weigh a ton.
My next option was a light gauge steel box tubing/and angle iron frame wrapped in sheet metal. This seems to come out in a similar weight and aside
From rust I feel has a very long term durability.
Then I stumbled onto overlandunderbudget’s Tacoma build and saw he used bonded aluminum or aluminum composite sheets for the skins on his camper.
Didn’t find anything with a search, so does anyone have experience working with this stuff? Would 6mm hold up to being the skins on a drawer system?
Hummelator
Have you looked into decked storage systems? I'm the 'I'd rather build it myself' type but decked has a great set up. And it gives you a nice flat platform that can support a good amount of weight ( evenly distributed)
I had a decked system for my 07 tundra with a 6.5 box. Weighed somewhere around 240# if I remember correctly.
BigBrokenZJ
I actually have a decked now, and it is great. I’m upgrading to a bigger fridge and and want to do a slightly larger single drawer next to a slide out tray.
NatersXJ6
If I wasn’t looking for weather-tight, I would build from 1/2” or 3/8” Baltic birch plywood. I did a lot of comparison between various materials when I started building my chuckbox and various storage boxes and always ended up with wood due to strength vs weight and ease of construction. 3/4” seems like heavy and overkill to me, but many choose it for screw holding and other construction ability.
Lockwoodjd
