Max Power?
Viggen
Just here...
How much power can the ZF and LT take? Thinking about a swap but am unsure of the power levels through the stock boxes. Thanks.
R_Lefebvre
Which ZF, the 22 or 24? That's the first question. And they're usually going to be rated by torque, not horsepower.
SeaRubi
use the zf4hp24's clutchpacks to rebuild your zf4hp22 ... that's what was recommended to me by a transmission shop. ymmv.
Yorker
The LT-230 can take some pretty good torque, you can also upgrade or eliminate its differential to make it stronger too. The zf4hp22 on the other hand I wouldn't want to put too much more power than stock through.
muskyman
really?
I was running 450 RWHP through one in my BMW 750 iL
they can be made really durable for sure, I am running the upgraded clutch packs in my 4hp22 in my disco.
Yorker
really?
Sure they can be made stronger but in stock form they are nothing to write home about. If you are going to swap another engine in you may as well look at other trannies too imho.
muskyman
I am not sure where you are getting this?
please link me to instances where people have toasted a 4hp22 from adding more power to the engine because I know of people that have bigger cams and headers and rimmer super chargers and such and have not had trans failures due to the increased power.
Auto trans fail from heat...keep them cool and they dont really fail that often. The torque convertor absorbs lots of the shock loads that would otherwise break components in a auto box. The TC takes those shock loads and slips and turns them into heat. So if you are adding more power and plan plan to use the trans hard look to increase the cooling of the unit and you then improve its ability to handle the increased power you are sending through it.
This isnt a rover thing its a car thing. ZF's are some of the best auto box's there are.
rovertech
No, the 24 is 15mm longer. Not a huge deal, but might cause the plates to not fit in the 22.
Overall length is increased not the case length. The difference is in the bell housing to accommodate a larger torque converter. The oil pump and other internals are different but case length is unchanged.
Clemtiger84
