Mercedes Benz Doka
terra-exp
Doka Mercedes Benz V8, 4WD, Diesel:
www.terra-exp.com represents 4wheel24 in the United States and the American Continent. Our goal is to boost the supply for fine “cabover” expedition trucks. The cabover design results in a shorter wheelbase which makes a truck more agile, more versatile and better maneuverable – not only off-road.
In the past 10 years, 4wheel24 has built 130+ expedition trucks. Our focus is to supply base trucks, sub-frames and cabins, as well as custom engineered equipment and products for long-distance travelling. The special needs of each single customer guides us to develop and plan a personal cabin layout. 4wheel24 supports installation equipment and material as well as furniture. We build-out your cabin but encourage you to be part of the build-out. Building an expedition truck is a lot of customization and fun.
For building a custom expedition truck, 4wheel24 at Terra-exp will be your one-stop shop! We have 70+ Mercedes Benz 4WD trucks waiting for you to be converted as expedition trucks.
1226AF:
OM442 II engine, 15.1l V8, Diesel Engine. 260hp 1,000Nm/750ftlb.
All Wheel Drive, cruising Speed: 65-70mph, 8mpg, with 48” tires.
Differential lock back axle and between front and back, high/low gearing, low milage.
Wheelbase 360cm/142”, very agile not only off-road.
Doka (crew cab = Doppelkabine), can be shortened to accommodate 4 people with air supported seats, instead of 9 on benches.
Highly dependable and robust engine and technic. No engine electronic, so easy to maintain and capable of combusting high sulfate Diesel (South America, Africa, Asia).
1429AF:
OM442 engine, 15.1l V8, Diesel Engine. 290hp 1,100Nm/800ftlb.
Shortened Doka, before and after:
We would convert these fire truck as expedition trucks. Here is what we have done in the past, and please visit us at:
https://www.instagram.com/4wheel24_fourwheeltwentyfour/
Thank you for your interest!
Martin Krauss
239-850-3663
www.terra-exp.com
tbnd88
