Mercedes Heavy Duty Sprinter 3500 cargo + luxury passenger areas
We were born on the road. one foot in the ocean, the other in the mountains. After years of searching for waves and adventure, opportunities and stories, we finally built the perfect vehicle for the...
losangeles.craigslist.org
We were born on the road. one foot in the ocean, the other in the mountains. After years of searching for waves and adventure, opportunities and stories, we finally built the perfect vehicle for the chase. The van spent most of its life with a metal grey wrap as can be seen in some of the pictures and as a result the paint is in excellent condition. Ideal for many uses this van has served us well and is ready to go onto a new home.
This van was built as one of the most advanced, luxury mobile film lab on four wheels. The dually can accommodate up to a 4100 lb payload, making it perfect for those who want to travel cargo while sitting separately in comfort. Popular in motorsport, this vehicle would make the perfect support car or motorcycle transport vehicle. Motocross champion Brian Deegan uses Sprinters on long distance races and Ken Block recently built two similarly specced transit vans to use for his fleet.
Here's a short video we made about the van:
Price: $45,000 OBO
Year: 2013
Make: Mercedes
Model: Sprinter Heavy Duty Sprinter 3500
Odometer: 99,886 miles
Note:
The van is currently located in Los Angeles, CA but transportation within the US could be arranged
Here are just a few of the many features built into this van:
- Custom interior built by ADF sprinters: http://automotivedesignsandfab.com
- Van interior is divided by wall partition out of aluminum & plywood covered in carpet rear section and Vinyl upholstered wood siding with insulation in the front and rear sections to reduce noise and insulate the van.
- Center partition is constructed of Aluminum core with wood siding wrapped in Vinyl/Carper from cargo compartment to reduced noise from cargo compartment and allow for mounting items to the partition. Pass through opening allows for running wires from the cargo compartment to the passenger compartment.
- Custom interior included seating for seven.
- 2nd row seating consists of 2x VIP Captains chairs with power base and recline
- 3rd row seating consists of leather Executive seats with three point seat belt
- Cargo compartment has been back with wood and has carpet on walls with vinyl ceiling.
- Auxiliary power system with 110 outlets throughout power by vehicle alternator when running, or power outlet allows plugging into any home 110 source when vehicle is off.
- Auxiliary battery system including battery tray relay circuit breakers and cabling
- 2000w power inverter
- Shore power via rv power mount with transfer switch and battery charger power supply
- Van is also equipped with top rack built out of aluminum with 1 1/2" upper rail and expanded metal floor
- Mounted on the roof rack is a goal zero yeti 400 power station + two boulder 50 solar panels for on the go solar charging and off-grid power: https://www.goalzero.com/shop/kits/goal-zero-yeti-400-power-station-boulder-50-solar-kit/
- In addition, a 13' awning is mounted on the side.
- Access to the roof rack via custom rear latter rack
- Interior railing also made of the same 1-1/2" tubing for mounting tv or other accessories.
- Led interior work lights in passenger and cargo area.
- Work & storage space in the rear.
- Adjustable shelves on both sides of cargo area.
- L-trac tie down rails in floor.
- Exterior led work lights
- Exterior 5x gallon gas can mount
- Offroad light bar w/ led lights
- There is a side access panel currently setup with a keg tap for iced coffee, this is a standard access panel and could be easily reconfigured to allow for additional cabling or other mounting points.
