Microphone/handset extention cord help needed
nwoods
I have an Icom 208H mobile 2m/70cm radio. It is mounted towards the rear of my vehicle, and logically enough I want the handset and the remote display in the front. Icom makes an extension cable that retails for $90, but I'm told a simple CAT5 cable will work just fine, and I can get those for under $10.
However, its not working.
I plug it in and everything works fine for a while, then after a few minutes, the handset will no longer work, adn the lights go out on the buttons. I think it's a power issue. The handset has lots of buttons and is illuminated (backlit). What do I need to enable power and signal to run from the base unit to the handset? If the cable is okay, (just a standard CAT5), what about the double female connector I am using, could that be my failure point?
Do I need CAT5e ? What does the 'e' stand for? I thought it meant 'enhanced' as in bandwidth, but could it be for powered Ethernet? Would a powered Ethernet rated cable and connector work? If so, what are they called?
M
MuddyOval
Guest
Regular cat5 is fine for that- you don't need 'e'
Sounds as if you have a bad crimp on the RJ45's or maybe the double female connector has a problem. Have you tried wiggling the ends of the cable to see if it's a bad crimp? I made my own cable for my 207h and it works fine, so the aftermarket approach DOES work. Many cables are poorly made these days.
nwoods
I'm on my third cable and second female coupler. I tested the microphone itself at HRO on their unit, and it's fine. I really don't think its the cable, I think its the coupler. I don't know what else to use.
I'm using (and not succeding) with one of these:
http://www.microcenter.com/single_product_results.phtml?product_id=0216279
Maybe I should try a slightly more expensive version?
http://www.microcenter.com/single_product_results.phtml?product_id=0216295
Is there something better I should try?
cnynrat
I did the same thing for my Kenwood TM-V71A installation, although with perhaps a shorter cable. I think I ended up with a 3' Cat-5 cable from the base unit to a remote jack for the microphone. Like your radio my mic has a bunch of backlit buttons also. Anyway, I don't see why your coupler shouldn't work, unless you just happen to have a defective one. How long is the cable you are using?
In case it may be useful to you, what I did was install a remote jack for my microphone - I used one of these that I bought from B&B Electronics. It's essentially a coupler that you can mount in a panel somewhere, and comes with a fairly dust/water resistant cap you can screw on when not in use.
I used the ENSP1F5 version, which has an RJ45 receptacle on the back side so you can simply plug the Cat-5 cable into the back.
mountainpete
Spamicus Eliminatus
The problem might be the pin sequence. If I remember correctly you need a CAT5 cable with an "A" sequence on one end and a "B" on the other.
Search Google for "how to make a cat5 cable" and check out the different color patterns. Even if your cable is right, the coupler may be reversing it again.
Pete
M
MuddyOval
Guest
Ooohhh, now that's sexy. Thanks for the tip!
I've been eyeballing the Kenwood V71A- is it true what they say about the display having problems or being hard to read? I'm torn between three different dual receive dual banders and I can't decide.
cnynrat
Not to hijack this thread too much, but I've had my V71A installed for little over a year and I haven't had any problems with the display. Some of the indications on the display are a little on the small side - things like the current power setting for example. I find them a little hard to read with my (older) eyes where I have the radio mounted, but it's workable.
Probably like most people I considered the Yaesu FT-8800 and a couple of the Icom models. In the end I decided I liked the ergos on the Kenwood, but I appreciate that can be a highly individual decision. I like the way they don't try to cram two complete sets of switches & buttons on the front panel, but instead provide an easy way to switch which side of the radio is being controlled back and forth. YMMV.
nwoods
Pete
That's a good tip Pete, I was completely unaware. Here are a few links I found:
- http://www.tomax7.com/aplus/APlusCD/cat5.htm
- http://www.mikestechblog.com/joomla...etwork-misc/73-how-to-make-a-cat-5-cable.html
nwoods
However....in thinking about this more, I don't think the A vs B thing is my problem. I am getting signal through for a short period of time, and then it fails. I wish they made female connector equipped RJ45 CAT5 cables!
nwoods
Time for confession. I think I figured it out. Every time I put the carpet back down over top the wiring, I think it was disconnecting the handset from the Cat5 coupler.
I lockwired it all together this evening, and using the same coupler posted above originally, it worked for a good solid hour. I leave in 30 hours for the Rubicon trail. Glad to have this sorted, even if the reason is embarrassing!
Goldenbora
