Military Schutt overland trailer with s788 shelter camper-IL
RUNEGLFBRG
Schutt HMMWV off-road generator trailer that I set up with a S-788 communication shelter. Perfect for off-road or overland camping. Has almost everything you can think of. Has dual front mounted aluminum tool cabinets. 120v/48v wall mount inverter with 48v 5.2Kw lithium wall mounted battery. Wired for solar just need the panels. Inverter can run off of shore power, battery pack or solar. Wired lighting and 120v interior and exterior outlets. Has 120v inverter AC. Includes diesel heater shown. It sits outside and has magnetic connections to a supply and return vent mounted inside. Has magnet covers for when traveling. Kitchen sink runs with dometic go tank and faucet. It drains out a hose port on outside so you can drain onto the ground or into a tank. Wide Nemo mat for second bed on floor. Rolls up small when not in use. When bunk is folded plenty of room for bikes or equipment. Has ARK corner steadies on the rear. I installed a set of folding steps that retract. I have a window I am including with it that could go in the door or wall I just didnt want to put it in since thats personal preference. Trailer was rewired with new 12v LED lights and 7 pin. Has a lunette ring hitch. Box is aluminum skin inside and out with corregated insulation. Trailer is steel frame with aluminum skin. I have montana title for trailer.
S788 outside dimensions
Height 67"
Width 84"
Length 102"
Weight 1500
Payload 2000
Inside dimensions
height 64.5"
width 81.5"
length 99.5"
Located 30min outside Chicago.
Looking to get $8900
stone23
