osidepunker
Hello!
I am planning out my electrical system upgrades and I have a few questions for the experts. First my planned setup:
Diehard Gold AGM 34 MB (main battery)
Two Diehard Platinum Marine 34 HBs (house batteries) mounted in the bed
IBS-DBS dual battery system with Relay Booster (enables starting with a totally dead main battery). 200 amps continuous, 500 amps surge ratings
200w solar panels and charger
My loads:
12.5k winch, max draw 420 amps
ARB 82q fidge
12v RV water pump
Lots of LED bars, radios, air pump, lockers etc.
12v and 120vac ports in key locations
I am planning for max draw on the HBs, which would be prolonged winching with a dead engine. With that in mind I am going to run 2/0 welding cable, POS and NEG, from the HB bank to the MB. It should be about a 16-18' cable run. 2/0 cable should also lower resistance for better solar charging on the MB. Couple questions:
I know I should fuse the 2/0 cable run at both ends, close to each battery. How do I choose a fuse size? What type of fuse should I use?
The HB bank will be two batteries in parallel mounted next to each other. Should I put a fuse between them? If so what size/type?
I am going to use military battery terminals with copper crimp terminal ends and a hammer crimper. Does anybody think I should go a different route for connections?
I need a MB and HB fuse and relay box for all my accessories. I have looked at Blue Sea, but they seem expensive and not enough connections I think. Are there any other solutions out there?
thanks for reading!
Does anyone have any suggestions for improvement or constructive criticism with my plan?
My loads:
ARB 82q fidge
12v RV water pump
thanks for reading!
