Moab, Utah: The missing link
hatchcanyon
Lancisti
Behind Hurrah Pass Chicken Corner is well known and Jackson Hole one of my favorites.
More to see and explore? Yes, indeed! There is a trail connection down to UT 211 into the Needles District. It is a long ride even if you will not need the two days I heard from.
In principle the road is mostly fun, except for a stretch of one mile through a little canyon without a name - we call it the missing link. This one is hard work. The difference in elevation between Chicken Corner Trail and the end of this nasty piece of work is about 330 feet. Sure one can find steeper trails but this one is a little bit mean - at last to me. But I learned there how to use wedging. You will need this technique for a short stretch (no pictures)
We have scanned slides from our first attempt in 1993 and from 2002. As often with scanned analog pictures quality is mediocre.
In 1993 we used a Ford Explorer from the first serie, in 2002 it was a Chevrolet Explorer.
1993:
Going around the first turn needs to back up
The trail in the little canyon
For a stretch of the trail my wife will drive the Explorer
On the passenger side with a camera
The last grade doesn't look that bad at first sight....
....but it may spite one
I am the spotter, will we get the car over that?
We did!
The proof is in the track
In 2002 with the Blazer:
Looking back to Deadhorse Point
Tilt but not toppled
Thats easier
Rocky
Trouble
Temperature was above 100°F as the coolant temperature raised quickly. To cure this I set heating to the highest stage, opening the doors to bring the heat out. It worked!
We decided not to challenge our luck. Turning the car was not easy within this tight spot but at last it worked.
unkamonkey
I believe I have done that tough bit of trail you speak of, but we came from the other direction and still got two jeeps hung up on rocks. It looks like Lockhart basin road. The rest of the trail is fairly easy. We came in from Indian Creek. A nice place to camp.
hatchcanyon
Lancisti
Yes, it is more or less the northern end of Lockhart Basin Road.
One often gets the recommendation not to try it from the Lockhart Basin side. In case that it is impossible to go down it is a long way back.
unkamonkey
Either way you drive it, It can turn into a long day on the trail. Every vehicle on our trip had a winch, we never needed them. OK, Daniel did winch his father off of a rock. His first time using one and he wanted to use the winch rather than a tow strap. Like a one ton, crew cab 4X4 diesel can't tow a CJ7 about a foot?
dhuss
