Mono or Poly?
tanuki.himself
i'm about to invest in a solar system for the roof of my slide-in camper. I'm planning on using Victron energy 175 watt panels as they are a good fit to my roof shape and dimensions and will allow me to add more pairs if I need to. The key question is whether to go monocrystalline or polycrystalline?- both are listed as the same weight, physical dimensions and output.
i will be using the camper mostly around Europe and north Africa from arctic circle to about 30 degrees north, and hopefully a shipped trip down to southern Africa which will be closer to the tropics for a few months. Panels will be horizontally roof mounted and will be the main power source for the camper - i would rather put on more solar that will work every day than rely on charging from the truck for when the camper is demounted or we are not driving.
I expect the biggest load will be a compressor fridge/freezer which I expect will use more power during the day and when it is hotter, so when more energy is available from the panels. I'll be fitting a 100/50 victron charge controller to give me headroom on the capacity and have a single (at present) 100Ah LiFePO4 house battery. I've been advised by the vendor to run the panels as pairs in series to give a more efficient supply to the controller.
given the latitudes and therefore sunshine angles and intensity, which panel is going to give me the best performance?
gtitonta
I am new for solar panel, but I had searched a lot of threads in this forum. You said that weight, physical dimensions and output of mono and poly are same. I am kind of wondering if there is any difference of max amp output between those panel? usually mono is better quality and tougher generally speaking. However, it is pretty much not much difference between mono and poly if the size and company are same.
Many people from this forum commented that solar panel for resident use is usually more efficient. So if you can find resident solar panel which fits to your roof, you should get one.
john61ct
And for maximum efficiency delta from MPPT like Victron, getting up to 40Voc rating or higher gets a bit more Ah per day actually into the bank.
The cheapie consumer-channel marketed panels tend to be much lower so as to not waste as much with cheaper PWM controllers.
luthj
Engineer In Residence
There is quite a variance within each group. You can find mono panels which are lower density than high end poly and vice versa. Poly panels tend to do better in cloudy conditions. Mono panels typically have more output per area, but these are not absolutes.
I would check to see if the temperature coefficient is the same for the panels. If one looses less output as it warms, that would provide a small boost in output at high temps. Conversely if you operate in cold weather all the time, the higher coefficient panel will produce more output when cold.
tanuki.himself
these are the figures for the two panels - temperature coefficients on the data sheets are identical across both types
the poly is 1 kilo heavier, but 19 euros cheaper......
FEATURES: BlueSolar Polycrystalline Photovoltaic Solar Panel VICTRON 175W / 12V
Polycrystalline photovoltaic solar panel ...
Polycrystalline solar module Victron Energy ...
€ 127.46 € 157.36 -19%
Reduced price!
Add to cart View
BlueSolar VICTRON 175W / 12V monocrystalline photovoltaic solar panel
Monocrystalline Photovoltaic Solar Panel ...
Monocrystalline solar module Victron Energy Bluesolar ...
€ 146.11 € 167.50 - € 21.39
Reduced price!
Add to cart View
Voltage12V12V
Solar panel power175 W175 W
Cell typePolycrystallineMonocrystalline
No. of cells36 cells36 cells
Solar module weight12 kg11 kg
Solar panel dimensions1485 × 668 × 30 mm1485 x 668 x 30 mm
Nominal power (Pmax)175 W175 W
Max Tension power (VMPP)18.319.4 V
Max current power (IMPP)9.569.03 A
Open Circuit Voltage (VOC)21.9023.7 V
Short Circuit Current (ISC)10.249.89 A
Input voltage12V12V
Output power175 W
Warranty5 years
dhuss
