I am looking for some install photos and/or directions. I have installed one before but I like knowing what I am looking at before starting. I have a 2003 Limited if it matters.
It's easy, just knock out the freeze plug that is the easiest to get to and the same size (it's really obvious) and the block heater installs in it's place. Push it in (i use permatex high tack or anerobic sealant on the o-ring) and tighten the bolt. Not super tight but just tight enough, it's brass so do it by feel.
I did one on the Jeep I had last year so I get the concept. Where is the freeze plug? Is it easy to get to? The Jeep one had to go in the passenger side rear most....
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
