Montero SR throttle body heater hoses
Hey everyone,
I'm digging into my 95 SR 6g74 DOHC at the moment, timing belt kit done, spark plugs, coils, and wires done, heater hoses done, replacing lower intake manifold as well. While i still have the manifold off, I noticed the two coolant hoses that come off the throttle body are a bit crusty and I'd like to replace them as well. I searched every online parts website and I can't seem to find the part numbers for these two hoses. Can anyone point me in the right direction? I'd like to go oem as they are molded hoses. Any help would be great, I'll post pictures when I can. Thanks.
These are the hoses in question:
Bumpety bump. I added two pictures from the FSM to clarify the parts needed. Id go to the mitsubishi dealer, but the closest one is about 40 miles from home and the parts guys know less than me. Id like to order it online but i cant find them in any of the catalogs.
Anyone?
Dprisner
I usually call Southwest Mitsubishi in Weatherford, TX - Just outside Fort Worth for OEM parts and speak with David or Robby in their Mitsubishi Parts Dept. Describe the parts needed and I bet they can give you part numbers and a discounted internet price. They usually ship to my house within 2-3 days (San Antonio).
JohnnyBfromPeoria
I'm Getting Around To It
I used non-molded silicone hose, even superior to OEM rubber, IMHO. The size is 3/8". Also, replace the 1/4" hoses that run behind the water pump if you're in the area. The last time my 95 SR got a timing belt before I bought it, they were not done, and one split, stranding the truck, all for about $5 in quality silicone hose. Real pain in the ***** to get to unless you're doing timing belt/water pump, etc., which is what I ended up having IncorporatedX do when mine went down. Ended up with new valve stem seals, hydraulic lifters, valve cover gaskets, timing components with an OEM tensioner, Aisin water pump (both halves), front cam seals, crank seal, crank timing gear and a new harmonic balancer. I already had the new crank bolt and washer, so just look at the savings right there!
John B.
iStan814
