I've had a problem for a while now with the tachometer on my Gen2 Montero sticking at about the 3500 rpm spot on the gauge. The needle moves a little bit with engine revs but within a very narrow range (within two of the small hash marks on the gauge). I tested the tach inputs on the the wiring harness with my volt meter and the meter needle tracks the engine revs perfectly, which leads me to believe the problem is with the tach itself.
When I pulled apart the gauge cluster and pulled the tach out, I saw a couple of wires behind the tach faceplate that were touching. "Ah ha!" I thought and separated the wires. When I put everything back together there was no change. The tach needle was still stuck in the same spot.
Has anyone ever had this problem or know of how to fix it?
Thanks,
Nik
Thanks,
Nik
